2000 Disco II will not shift out of park
Old 08-18-2007, 10:09 AM
johnny's Avatar
Default 2000 Disco II will not shift out of park
My 2000 Disco II is stuck at the office and will not shift out of park. The other day the service engine light came on but I thought it was due to the gas cap. Anyway now the Differetial Lock light comes on when I press the brake and it will not shift out of park. Please someone help! It starts fine it just won't shift into gear. This Differential Lock is only something that the dealer may turn on while they are working on it. I have not been to the dealer. Any suggestions? Thanks.
Old 08-18-2007, 10:44 AM
okdiscoguy's Avatar
Default RE: 2000 Disco II will not shift out of park
You can engage the diff lock under the truck on top of the transfer case. On the D1's the shifter moves from side to side to engage it. Make sure your brake light switch is ok. Can you hear the click by the shifter allowing it to be moved? Should hear 3 click 1 brake light switch engaging the lights, 2 gear shift brake lockout, 3 brake light switch for cruise.
I'll see if I can find a pic of the diff lock switch for you.
If you get it going, take it to you local auto parts store and have them pull the codes (for free) and get back to us.
Old 08-18-2007, 10:46 AM
I would suggest you call me, sounds like you need a little help on fixing this issue. In the mean time, have someone stand behind your truck and see if you have any brake lights.
Call me.
303-862-7680
Colorado
Old 08-18-2007, 11:52 AM
scottagnew101's Avatar
It Sounds like it might be the NSS (Neutral Safety Switch) located behind the brake pedal
Old 08-19-2007, 09:43 PM
johnny's Avatar
I really appreciate the suggestions! I will work on it tomorrow and get back to you all. Disco Mike sorry I was out of pocket today. I will try to call tomorrow afternoon or evening what ever works best for you?
Old 08-23-2007, 09:14 PM
yarddawg's Avatar
Ok, so I have this EXACT problem on my 2000 Disco II. Except no warning lights are on. The only thing I can't do is shift out of park. I noticed that the brake pedal felt strange. So...
I had my wife stand behind the car as I pressed on the brake.... Nothing. With the car running or when it's not. It seems to me that the shift lock won't release because the brakes aren't registering.
HELP!
Old 08-24-2007, 08:47 AM
You have a failed brake light switch located on the brake pedal arm, replace it, takes just a couple of minutes to do, and you'll be fine.
Old 08-24-2007, 09:30 AM
yarddawg's Avatar
wow, that would be awesome. now, could you tell me what the part is and where I can find it? Thanks!
Old 08-24-2007, 10:04 AM
I did in my last post, and you can usually find it at most auto part stores.
Old 08-24-2007, 10:08 AM
98roverguy's Avatar
Try this.. Get it based on your year/model. http://www.roverparts.com/Parts/XKB000010.cfm
Quick Reply: 2000 Disco II will not shift out of park
