-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   2000 Discovery II - Engine shuts off unexpectantly (https://landroverforums.com/forum/discovery-ii-18/2000-discovery-ii-engine-shuts-off-unexpectantly-79091/)
Sonja Hindman Graham Apr 30, 2016 06:00 PM
I'm having a problem with the engine, it will stop running randomly, sometimes it will start back immediately, sometimes it takes 15 min. or longer. I've replaced the camshaft sensor twice, that seems to help for about 6 - 9 mo. then it starts again. All lights on the dash will come on for no reason, then I can shut the car off and when it starts again.... they are all off. Any suggestions or has anyone else had similar problems? It has 250K miles on it.
shady milkman Apr 30, 2016 06:25 PM
Sounds like fuel pump could be going out
Sonja Hindman Graham Apr 30, 2016 06:29 PM
Thanks, do you know if there is any way to check the fuel pumps pressure short of going to a Land Rover dealer?
shady milkman Apr 30, 2016 07:11 PM
Any local shop can test it. I had the same thing happen to me on my old D2, it's a pain to get to the fuel pump, but once you get to it, it's pretty simple to put the new pump in. If you find out that's what the issue is I can look up which airtex model fuel pump I replaced it with
Charlie_V Apr 30, 2016 08:13 PM
You can check the fuel pressure at the Schrader valve on the driver side of the back of the upper intake. You have to kind of feel for it.
mln01 May 1, 2016 06:12 AM
This is the classic symptom of a failing crankshaft position sensor. You say the camshaft sensor was replaced twice -- is that what you meant to say or did you mean to say crankshaft position sensor? These trucks have both.
Charlie_V May 1, 2016 08:35 AM
I was wondering the same. Cam sensor is on the front cover. Crank sensor is on the bottom driver side of the engine, just above the oil pan at the back. Crank sensor is the likely culprit.
rankar May 1, 2016 05:13 PM
yup. and very susceptible to failure from moisture if not installed correctly.
