2001 Disco 2 Horn not working
Hope someone can make some sense.
Horn stopped working for no reason.
1. Checked the Buttons they are ok
2. Checked 10A fuse - OK
3. Relay bases there is power
This is where it gets strange
4. Took the Horns out connected with Battery directly individually - does not work. Does not look like in need to Ground this.
5. There is no power at the connector
I can understand either #4 or #5 not working.
I found this post - but the pin numbers on Relay are #1 through #5 not pins 30 and 87 on the relay base the post says
https://landroverforums.com/forum/ge...working-45858/
Any help will be appreciated
Thanks
Thanks
schwaggy
04-25-2012 01:56 PM
johnkbl
12-29-2008 11:15 AM
