2001 Disco Alternator Specs - Winter Package?
I have a 2001 disco w/ winter packageand the alternator went out on it. I had it replaced by my mechanic and he mentioned that it was a high amperage one... well it died within a month and he replaced it assuming it was just a dud.. well, a few months later it has just died again. The only thing I can pick out that I had done around the time it died was use the front and back window de-icers. Is the amperage requirements for the alternator different when you get the winter package? And does anyone have the specs on the alternator it requires?
Thanks!
Thanks!
RE: 2001 Disco Alternator Specs - Winter Package?
He didn't say what amperage, but it's a bosch alternator. I'm going to see if I can get a part number off it and find out if it's not a 130. I have been using this guy for a long time and he is actually a friend of the family..so I do trust him. I found 130 amp land rover alt from a junk yard for 60 bux.. should I grab it?
a little more history.. I had a stone crack my windshield and the heated front shorted out and actually fused the drive side winshield plugs together. Problems seemed to havestarted when this happened. I have since changed the windshield.
Roverrocks
01-01-2014 11:45 PM
JumPeR04
12-17-2009 07:57 PM
mgabriel
12-11-2008 11:53 PM
