2002 DII Crank Sensor Location
Where is the crank sensor located? How can I access it? Based on my P0335 code, it needs replaced. I have another on the way but have through the top of the engine compartment as well as underneath and not found anything that resembles the picture of the part.
Any helpful hints?
My mechanic (see last weekend's post) said he would install the part and not charge labor. I just moved my LR so my kids could play basketball and it just isn't running right. Mechanic is 20 mins down the road and I am not sure if she'll make it. I really don't have the time to make the repair, but I have even less to stand on the side of the road broken down.
Any helpful hints?
RE: 2002 DII Crank Sensor Location
It is on the driver side bell housing with a cover over it that looks like a small motor housing similar to a starter motor, but much smaller. Two 7mm nuts to remove the cover then two more to remove the sensor. The plug runs straight up from there, and is very difficult to get to unless you have very small hands and forearms. I had to bend the wheel well a little to get my arm through the side instead of going up between the frame and the exhaust pipe.
mtfife
mtfife
Arizona man
01-14-2011 10:43 AM
Roveroh
08-07-2008 09:42 AM
