2002 disco won't shift out of park when cold?
You will need to replace a switch on your brake pedal.
I think there are two of them - brake lights and the ABS.
Might be one more for the park lock.
The switch pulls in a magnetic solenoid which pulls back the lock bar on the transmission shifter.
You can hear it clicking when you push down the brake pedal and you are in park if you listen closely and it is working.
charliesdiscovery
06-06-2008 02:39 PM
