2003 disco leaking fluid from under driver's side
Looked under car today to see where leak was coming from and the steering parts are wet. Leaking steering fluid?
1 Attachment(s)
Pictures from under the driver's side.
put some uv additive in and find the source.
my guess= return line or the pump |
After I take out the p/s fluid with a turkey baster, then do I add the uv additive in or keep the p/s fluid in and add the uv stuff.?
Just top it off with the additive.
Only takes a tiny bit and the pump will circulate and mix it |
| All times are GMT -5. The time now is 06:37 AM. |
