2003 Discovery: Replace engine or scrap it? Looking for advice
Here's the thread on how to do it: https://landroverforums.com/forum/discovery-ii-18/d2-inline-thermostat-mod-32216/
You should shop around,
A good LR indy should be charging around 2k for HG's and similar for cam/lifters. With labor you should be around $4k, not 6. And thats paying full labor costs. Do some of the work yourself and cut the cost from there.
The cam shaft itself if a few hundred, lifters under $100, might as well do oil pump and timing chain if that has not already been done. HG parts are under $400.
All the rest is labor.
If your engine was decent before needing HG's and cam/lifters it should be restoreable.
hard numbers
I'm doing what I suggested (and what is suggested above) right now with a 4.6 I took off a parts truck I bought. It had a bad head gasket. I decided to have the engine totally redone.
HG kit is 140
Head bolts 75
Camshaft -- I got an upgraded one -- 275
Crank turned (made new, basically), block cleaned, cylinders honed, valves seated, heads planed, everything pressure tested, camshaft installed, new ring and main bearings -- about 800
New oil pump, water pump, and steering pump with all gaskets -- about 300
New hoses (ALL the engine compartment) -- about 275
New radiator -- 156
Inline thermostat mod -- about 70 dollars
New lifters -- 110
All new fluids, front to back -- maybe 150
I dont know what that adds up to but it is basically a new engine.
The head gasket kit and bolts are about 215 dollars shipped. You can replace them with basic tools in a weekend in your garage, with the engine still in your truck.
HG kit is 140
Head bolts 75
New radiator -- 156
New lifters -- 110
