2003 Discovery steering binds
Does anyone know if the Disco 2 has the same problem that the Disco 1 has with the u-joint in the steering shaft causing the steering to bind up? When I go to turn the wheel very far, it stops. If I give it more force it continues turning. I won't lie, I haven't done too much troubleshooting yet. I checked to make sure there was plenty of power steering fluid and I checked for a beat up steering stabilizer. Both of those looked ok.
Thanks! |
Never mind. I should have looked a little harder before posting. It looks like I have a broken engine mount. The mount is pressing against the steering shaft joint.
If its not the U Joint, check your Drag Link and Tie Rod. My Disco 2 would lock-up when trying to recover from a left had turn. Here's what I found:
https://cimg9.ibsrv.net/gimg/landrov...1bc7f91b61.jpg |
| All times are GMT -5. The time now is 08:49 AM. |
