2004 discovery long or short nose differential?
I'm surprised that Google isn't more help with this. I'm trying to determine if a 4 pin p38 differential is a direct replacement for a D2 diff, as well as all the others applicable differences.
Any help with this guy's? Figured someone here would be an axle aficionado
Originally Posted by KingKoopa
(Post 613436)
I'd post on disco web. When I need real help that's where I post. |
Way too technical for this crowd!! Haha. I'd post on disco web. When I need real help that's where I post. P38 is 4pin & D2 is a 2pin. I remember Kyle from DFW tried it, but in the end I think he gave up. The P38 has a stronger axle setup with larger tubes, and 4 vs 2 pin, but if I remember correctly the axle splines are the same. |
This might help a bit.
p38 and d2 differential differences? - Pirate4x4.Com : 4x4 and Off-Road Forum https://discoweb.org/showthread.php?t=71539 http://forum.lro.com/viewtopic.php?f=18&t=94192 And this vid will answermost if not all of your questions. |
