2004 misfire and ticking?
Well I have done some searching and now don't know what to think.
First off I'm a auto tech at a small auto shop so I do know a lot I just know that there are people that know a lot more about land rovers than I do
Start up cold no ticking just a exhaust leak on the pass side ( I can find that ) but engine has a misfire
engine warms up and exhaust leak gets little better (makes sense) but as engine gets warmer there is a louder ticking noise (sounds like lifter noise) the ticking goes away when RPMs come up or driving down the road. After a good drive come to stop, the ticking is not as loud but if you let the engine idle for a few minutes the tick is back strong and loud.
I pulled codes and got p0203 and p0303 and from what I found on the internet is 1 is cly #3 misfire and cly#3 injector.
Someone put new plugs in but i'm not sure what they are yet because I have not pulled them out I wanted to order the right plugs to put back in and I noticed the wires are not looking so good so I will change those as well.
I think the exhaust leak and the misfire should be straight forward, I'm just a puzzled with this ticking sound.
Any Land Rover geniuses out there
Thanks
Mark
Thanks
Mark
www.apexperformance.net for the plug wires, Magnecor wires or you will be doing it again in a month.
Are you using premium gas?
It sounds to me like you have excessive engine sludge or a weak oil pump.
If you do not run premium gas you will sludge up the engine faster than a prom dress comes off.
Humdinger
10-18-2016 05:05 PM
john65b
10-10-2013 05:00 PM
