3 amigos / abs sensors help
Old 12-03-2021, 09:33 AM
matt3502's Avatar
Default Shuttle valve/Option B
I have attached what I have on doing Option B. Hope these help. 3 Amigos need to be deported ASAP!
File Type: docx
H Hill (12-06-2021)
Old 12-05-2021, 02:50 PM
BS50MGSXR's Avatar
So these SLABS plugs are located where? driver side or passenger side under the Dash? under the Hood?
Also found this big plug on the passenger side to the right of the dash blower motor not plugged into anything and I see nothing for it to plug into either.
Old 12-06-2021, 06:18 AM
H Hill's Avatar
Thanks, matt3502!
I have the Falconworks kit and am ready to do the seals AND redo the Option B fix at the same time. The only copy I had was a PDF and it was not complete.
Odd this is, when the kit arrived, the 3 amigos went away and have not returned for 4 days. I plan to wait until they show up again to do the repair.
Will keep everyone posted and possibly with pictures as well.
matt3502 (12-06-2021)
Old 12-06-2021, 09:31 AM
mln01's Avatar
The big connector you are pictured holding is for the ACE system (Active Cornering Enhancement).
The SLABS computer is located nearby, above and to the left of where your hand is in your picture. The gray metal in the upper left corner of your pic is the same location as the red metal in my pic. The wheel speed sensor connector is the one plugged into the SLABS nearest the firewall. Look for the wiring bundle with the green, brown and white wires as shown in my pic.
Old 12-07-2021, 10:26 PM
redrover75's Avatar
Originally Posted by H Hill
Thanks, matt3502!
I told you, it's magic. Might just be an electronic connection.
Old 12-08-2021, 08:07 PM
H Hill's Avatar
Agreed. I believe that the 3 amigos were frightened by the repair kit, and hid. Then came back today for about 45 minutes of driving, then left and haven't returned. Just when I get ready to install the kit, they leave.
The Rover gods are chuckling, I'm sure.
OffroadFrance
07-09-2021 09:15 AM
ralphobell
03-15-2014 07:41 AM
jkid
12-21-2009 10:25 AM
fjaber
01-18-2007 06:42 PM
Quick Reply: 3 amigos / abs sensors help
