3 Amigos -- Urg!
3 Amigos issues -- UPDATE -- odd event
UPDATE UPDATE - OCT 16, 2011
I have some really odd updates on the 3 Amigos.
A few months back I got the 3 amigos when I was driving. I shut the engine down for 5 minites and it went away. It became more frequent, from every 2 weeks to once a week, to daily, to just driving a few miles.
Then the "CHECK ENGINE" light came on about a week ago, and the 3 amigos became less frequent. In fact, I only seen them twice since the check engine light came on, and haven't seen them for 4-5 days now, which is very odd because they became more frequent and almost permanent after a month.
I spoke to the dealer and planned to take the disco in for reading of the 3 amigos and the check engine light, BUT 1 1/2 days ago the check engine went AWAY!! ???? And it hasn't come back on and no 3 amigos?
Can I really be this lucky that the car just fixed "itself"?
Is that even a possibility or should I assume they will return in a few days. but why would the check engine light be on for a week, an then just go away??
Anyone with some insights?
Is that the only possibility or is it possible it was fixed on its own? Also, how would that explain the ABS Amigos becoming more and more frequent to not appearing at all, when the check engine light was on a few days ago?
nothing fixes itself, except the terminator... the CEL and 3 amigos lights can very well be unrelated. if the 3 amigos lights was on and now is off that tells me it is most likely a hub. if it were a speed sensor it would come on right when you start the truck. the hub needs to be rolling to wobble. needless to say... you still need an ABS amigo and a ODB2 code reader if you want to solve your problems. note the s. problems.
