3 amigos - Why Scanner Won't Clear "Shuttle valve switch electrical failure" CODE
I have an Autolink AL619 ( just purchased from amazon) scanner seems to be all up to date, I am able to clear all the OBD codes and also was able to access ABS codes but when I hit erase codes it will not erase this could and the 3 amigos are still there, from what I researched this scanner has got rid of the three amigos code from the abs from other users any idea why it won't clear?? Any advice would be most appreciated.
is there a way for me to check if this was fixed visually without removing the modulator?
If Option B has been done, you should see the yellow/green wire pulled from the bundle and spliced into another wire that runs under the the modulator to the shuttle valve switches. In the installation pictured, the wire is connected via a two-wire trailer light connector.
You'd also find another wire running from the shuttle valve switches to a ground point. In the pics it also runs through the trailer wire connector. The original Option B instructions showed the ground connected to the A/C line clamp, as shown.
