-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   3" OME: spring seat or spacer in rear? (https://landroverforums.com/forum/discovery-ii-18/3-ome-spring-seat-spacer-rear-30217/)
oysterhead Apr 5, 2010 11:03 PM
Alright, so I'm back and forth every 6 hours but I think I've made up my mind on my setup. Plan to pull the trigger tomorrow!
751s in front and 762s in rear
I don't want the rear to sit lower, so I'll either
1. Add D1 spring seats to rear
2. Add 1" spacers in the rear
Any difference in performance or preference between #1 and #2? The spacers are easier to get, I can just have Lucky8 send them with the kit.
Thoughts? Thanks.
rj95lss Apr 5, 2010 11:10 PM
I think there were some D1 spring seats on eBay the other day or there has to be a junk yard within 200 miles of you with a D1 in it.
I personally would try to find them over using a spacer if I had the time/money/option. I guess I don't really have any technical thoughts just personal preference to use OE parts instead of adding something in that everything around it wasn't designed to be used with necessarily. I know that probably doesn't make sense, just my thoughts I guess...
Also if you get into your install and find that your retaining rings on the front are shot let me know as I ordered some from L8 and didn't use them (still in Terrafirma factory package).
GL-
oysterhead Apr 6, 2010 09:12 AM
thanks GL.
anyone else have thoughts?
if i buy used spring perches, do i need the hardware off the D1, too? (bolts, etc.)
oysterhead Apr 6, 2010 08:04 PM
to finish this thread, i went with:
751s in the front. 762s + 1" spacer in rear.
greenwade Apr 6, 2010 11:58 PM
pics?
oysterhead Apr 7, 2010 07:05 AM
just pulled the trigger, havent yet done the install.
so i guess the thread isnt yet finished.
Disco Mike Apr 7, 2010 09:27 AM
So since you are concerned about keeping the height even, do you have a front winch and or bumper cause that will play into what you need for the rear?
oysterhead Apr 7, 2010 07:12 PM
no Mike I don't yet have a winch bumper.
that's why i figured i need the 1" spacer in the rear.
rj95lss Apr 7, 2010 07:18 PM
I think he is saying that even with that spacer your front will still sit high using those springs. The 751 springs on the front without a winch/bumper is going to give you more like 4in of lift and 762 + spacer in the back is going to give you more like 3in.
Are you planing on doing a bumper at some point?
oysterhead Apr 7, 2010 07:27 PM
yes, at some point.
but don't want to be nose-high in the meantime.
