4.6 - Oil Leakagage
4.6 - Oil Leakage
Hi Folks,
2 days ago I bought a 2003 Discovery, 4.6 HSE, with 130000mls.
Today, after a 30 miles trip on the highway, the car had a lot of smoke behind, coming from oil drops burned on the hot exhaust.
I can’t see exactly, where the oil is coming from, there is all over, beginning from the front axle to the transfer case.
What are the typical problems which could cause a oil leakage which I could check tomorrow.
I’m new to the Discovery, but I owe a Defender since 2002.
Does somebody know a good workshop to bring the Discovery for a repair?
Tanks a lot in advance, and sorry for my poor English, I’m from Germany.
Picture after arriving home:
Last edited by ThomasFS; 01-27-2015 at 12:37 PM. Reason: Misstype in headline, bad for searches.
My guess would be the front cover leaking or the valve cover gaskets, probably both.
This guy in Florida is a well regarded member of the Rover community not sure where you are located though...
The Rover Shop, Fort Lauderdale, Florida 954-767-6837.
ThomasFS (01-25-2015)
We are in Orlando FL, a shop nearby would be helpful, but thanks for the contact in Fort Lauderdale. I guess he can give some helpful hints what I could do.
Check the screw in plugs in the front oil pump/timing cover where an oil pump would connect. 2003 doesn't have an oil cooler and the blanking plugs they used to delete it do get loose. I had one back out part way and was getting oil all the way onto the back bumper. Screw in plugs with a hex head for a socket...don't remember the size.
Today I did some cleaning and I think the oil is coming somewhere from the upper region of the front engine cover.
I also found the screws of the oil pan a little loose, but not much, and tightened them.
Tomorrow I try to find a mechanic to have a look to the oil leakage.
What could be the average price, to put in a new seal to the front cover and the oil pan?
Any suggestions for a good mechanic for Land Rovers in Orlando FL?
Thanks in advance ....
