4 service engine codes...need your help!
hey guys. have an 03 disco with 101,000 mi. service engine light recently came on. here are the codes i pulled.
P 1412 1415 0308 (this code showed up twice for some reason) 0300 please help me out guys! i am a total rookie with auto mechanics. what do these codes mean? which ones require immediate attention? also, any ideas on repair costs (again, im a rookie, these repairs will be done by a mechanic, not myself). i also want to note that the first time the light showed up (came on immediately after i started the disco, still in park) the SES light flashed/blinked maybe 8-10 times, it hadn't been drove for about 2 weeks. i have maybe drove it 5 miles since the light showed up it has not flashed again. I REALLY APPRECIATE ANY HELP GUYS! THANKS! |
Originally Posted by morzy41
(Post 178323)
P 1412 1415 0308 (this code showed up twice for some reason) 0300 please help me out guys! i am a total rookie with auto mechanics. what do these codes mean? which ones require immediate attention? also, any ideas on repair costs (again, im a rookie, these repairs will be done by a mechanic, not myself). i also want to note that the first time the light showed up (came on immediately after i started the disco, still in park) the SES light flashed/blinked maybe 8-10 times, it hadn't been drove for about 2 weeks. i have maybe drove it 5 miles since the light showed up it has not flashed again. I REALLY APPRECIATE ANY HELP GUYS! THANKS! 308 misfire cylinder 8 1412 sounds familiar maybe another one I've run into in the past too.. I'm THINKING the codes that led me to change out the Mass Airflow Sensor?? That was a part of my Three Amigos issue. I had the 300 codes, and the intermittent blinking/ solid on Service Engine light.. the changing of the plugs and wires fixed it. |
P1412 Secondary Air Injection System – Malfunction Bank 1 LH (Insufficient SAI flow
during passive test) P1415 Secondary Air Injection System – Malfunction Bank 2 RH (Insufficient SAI flow during passive test) P0308 Cylinder 8 misfire detected Excess emissions level of misfire detected on cylinder No.8 Assuming you also got P1308 No description Catalyst damaging level of misfire detected on cylinder No.8 P0300 Random/multiple cylinder misfire detected Excess emissions level of misfire on more than one cylinder So you have an SAI issue, check the connections and also a misfire on 8. When was your last real tuneup? |
is the SAI pump what is making the loud (sounds like a fan) noise for 30-45 seconds from a cold start? ive noticed this happens only when the vehicle is un-driven for 5+hours
Yes that is normal when the engine is cold. I believe the SAI is on the USA passenger (right) side and there is a pump, selenoid, and valve and a bunch of lines that feed in to the head. Follow the lines and make sure everything is connected first. For reference here are the parts to look for:
http://www.RoverParts.com/Nxt/search...ords=secondary |
So start with the basics, when was it last tuned along with new 8 mm plug wires and what octane gas are you using?
As for the 2 1400 codes, find a mechanic who is familiar with the SAI system, try to stay away from the dealer. |
I have an 03 D2 and have my share of codes. I have had P0150 P0174 P1174 and P1415. Seems like these things are a code nightmare but dammit they look and drive good. I am not sure how to start a thread on here
My local shop quoted me $350 JUST IN LABOR to replace spark plugs and wires!!! Am I crazy or does this seem very high? This price doesn't even include parts!
Originally Posted by r.pollreis
(Post 178447)
(Post 178486)
my local shop quoted me $350 just in labor to replace spark plugs and wires!!! Am i crazy or does this seem very high? This price doesn't even include parts!
