40AMP passenger seat fuse keeps popping but only when reclining...
Old 02-21-2021, 03:13 PM
GoRoll's Avatar
Default 40AMP passenger seat fuse keeps popping but only when reclining...
Going back and forth is ok but when reclining, it blows the fuse.
I checked the wires and panel, seems to be ok.
Old 02-21-2021, 04:54 PM
mollusc's Avatar
The two types of movement use a different motor, so maybe the motor for the recline/raise has a short.
Old 02-21-2021, 10:04 PM
Discorama's Avatar
Looks like the motor for reclining is bad. When you are at it and your pass seat is not fitted with the height adjustment motors and mechanics, I would try to get a seat base with that. The stock switches and wires provide the power for these two additional motors already. I got a used seat base with motors for under $100 from ebay.
Old 02-23-2021, 04:09 PM
zski128's Avatar
@GoRoll I have a bunch of seat parts as I just replaced my seats in my D2. The seat base is heavy so it could be expensive to ship but I do have the motors. Let me know
Old 03-10-2021, 06:37 PM
GoRoll's Avatar
how much, I might go to the junkyard tomorrow to just swap the controller see if that fixes it
GoRoll's Avatar
Also, any ways to have the seat up? I don’t want to burn the wire but I may run a heavier amp just to be able to recline it up lol
Old 03-10-2021, 06:40 PM
GoRoll's Avatar
is this the one underneath? You got a photo?
Old 03-10-2021, 09:22 PM
Discorama's Avatar
I don't have photos. The seat comes with one two or three four motors. If you have three four motors, which one do you mean?
EDIT: I forgot the forward/reward motor, so there are two or four motors in a seat. Corrected it above.
This picture shows the motor for the recline:
Old 03-11-2021, 05:47 AM
zski128's Avatar
The recline motor is really buried in there. You will need to almost completely disassemble the seat back to get to it. I would suggest to swap the entire seat or just the seat back instead did trying to replace the motor.
Old 03-11-2021, 10:58 AM
GoRoll's Avatar
hahah its super recline. I may just run to the yard, get tons of fuses at the moment and adjust it bit by bit. I have a trailing trip tomorrow and I gotta bring my kids.
lol
Quick Reply: 40AMP passenger seat fuse keeps popping but only when reclining...
