60k service
What are some good things to do at 60k other than fluids and plugs?
RE: 60k service
Try a search, Disco Mike was kind enough to compile the perfect 60K list. I don't know what it's under but it's around here somewhere.
RE: 60k service
Here is my list, if you have any questions shout.
This is the parts list for a 60,000 mile service or a high mileage used truck, the way I do it. 1 Oil filter, K&N 3001 1 Air filter 6 Qts of engine oil 12 Qts of ATF 7 Qts of 80/90W gear oil 2 Qts of Brake fluid 2 Qts of synthetic Power steering fluid 2 Gallons of OAT, orange coolant 1 Bottle of Lucas Power Steering additive 1 Bottle of Lucas Transmission additive 1 Can of Spray Carb. Spray 1 Can Of Brake cleaner 8 Spark Plugs, I use Bosch Platium Plus 4's 1 Set of Magnacor 8mm plug wires 1 Serpentine belt if not yet replaced 2 Bottles of SeaFoam 60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased Bleed the brakes Flush and change the power steering fluid adding one bottle of additive Service the tranny adding one bottle of additive Flush the coolant system Do an engine flush before changing the oil Do an induction cleaning Clean the throttle body Add fuel additive to full gas tank Change both of the diffs fluid Change the t/case oil Replace the plugs and wires Replace the air filter Lube all the drive shaft grease fitting including the 2 slip shafts Do full inspection of brakes, hoses, bushings etc. Hopefully I didn't leave anything out. |
RE: 60k service
I have a couple questions.
I do not know how to do the service myself. Should I bring the truck to the dealer, or an independent shop. I live in Indianapolis, and the LR dealer is Tom Woods. Any recommended independent shops? Is going to a local shop life Firetone, Midas..etc a good or bad idea? Dealer quoted me $1100 for the 60K. Does this sound right? If I get it done at the dealer, do I need to specify any special parts or services that are not included in DiscoMikes list? Thanks. |
RE: 60k service
It sounds pretty expensive. If you have time I suggest you do it yourself. You will save a lot (it will cost me approximately 400$).
I'm working on a "how to do the 60k maintenance" with pictures should be online at the same time I finish my 60k maintenance :P |
RE: 60k service
That price sounds about right, as far as dealer prices go. If you do some of the work yourself you can save extra cash, and become more comfortable with your truck. Changing the motor oil, diff oil, tranny fluid, and t-case (though the fill plug can be a pita) is very easy to do on your own. I never did an oil change before getting my D2 and in the past year I've done a ton of work on my truck.
RE: 60k service
You can do one or two things at a time weekend by weekend. You will need a hand held fluid pump though, about $10.
RE: 60k service
If you do all on my list you will pay apx$300 in parts and fluids, save you a huge chunk of money, the job is pretty easy and a great way to figure out what makes your truck tick.
RE: 60k service
What is the seafoam for?
RE: 60k service
Induction cleaning and fuel injector cleaner.
| All times are GMT -5. The time now is 07:03 AM. |
