7mm vs. 8mm spark plug wires
True, these trucks are always going to have issues. But there are definitely things that you can do to change things for the better. There aren't any magic fixes, but when you use quality parts you're bettering your odds. Quality doesn't always mean most expensive. A quality 8mm silicone wire is going to make a difference, and will usually last much longer.
You won't be disappointed, besides they are just wires and you probably wouldn't notice a differenct if you installed the cheapest vs. the most expensive wires. I always try to buy the best at the lowest price. Does the best really make a difference, most likely not, but piece of mind does weigh in on it a lot.
cosmiccharlie
05-13-2015 10:45 AM
Disco Den
03-28-2010 12:42 PM
