95 Disco "OBD" plug Located?
Im looking for the OBD plug location on a 95 Disco.
RE: 95 Disco "OBD" plug Located?
OBD 2 did not come out til 96. Look below the passengers seat, its got a little box that has an LED read out on it. It's about 2/3 the size of a cigarette pack
Clean out your stepper motor, and replace the vacuum advance on the distributor. Words from my father. ( LR Mechanic ) good luck. -Houston |
there is a white plug under the footwell on the right side, unplug it for 5sec, then tunk key off untill main relay drops outto clear the code and move on to the next
For a 95 Disco, remove the pass. side kick panel(covering the blower motor). You will find a white 5-prong connector. There will be a single black wire going to one side and three wires(can't remember the colors) on the other side. Plug T-4 into the 3 wire side to read faults, provided you have the correct connector.
-Kyle |
