99 disco with ace /now w/o ace
so I bought a parts car and the person before disconnected the ace by changing the belt .Leaving out the cornering pulley , would this affect the power steering ? ... i bought it as a parts car but am thinking of salvaging her , and is oil in the air intake normal.
No that will not affect the power steering but it will not handle correctly.
No there is not supposed to be oil in the intake. How well does it run? |
it ran good it has a leak around the timing chain is what he said but the air filter is clean..the reason i ask is I could probably us the pas pump but no more fluid in the resivoir
if the ACE has been disconnected then I would "assume" that you would be pretty much running the truck without the ad of swaybars, I would think.
Why would you disconnect the ACE, it is one of the better features on your Disco.
i bought the truck that way he ran the resivoir dry I am fix my 99 disco II with it ..iy supposedly started rocking back and forth when he was driving it....
rotors?
does that little center nut have to come out or not ,i ve found conflicting awnsers my rotor doesnt want to come off? and the rave says it does but I cant remove it ...
