99 Disco II with 6 codes and three amigoes... please help where to start :)
Also I think I will purchase just the two front O2 sensors for now. When I was searching the O2 sensor codes they all seemed to be front related.
P0152 02 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
Sensor 1 means front O2 sensor and Sensor 2 refers to rear sensor right? Bank 1 is driverside and Bank 2 is passenger?
Vac leak your talking about that hard plastic line runs behind the motor over to the driver side to the brake booster, you will find it towards the bottom of the booster and it has a big rubberish plug on that end. You could find the crack and cut the line there cut out a inch or two section and then go to hardware store and find a hose that's big enough to slip over original hard plastic line, go home and put some adhesive on the original line and slip new hose over both ends let seal and your good.
