99 Land rover Discovery II firing order
anybody have a firing order diagram for a 99 land rover discovery II. I need to know the firing order...and If sombody has picture diagram availbe it would be a great help. Thanks...RYAN
RE: 99 Land rover Discovery II firing order
This is for a 1999 4.0 Range rover i don't know if they had the same motors but this is the order.
http://site.wikianswers.com/template...s/qbar_ptr.gif http://site.wikianswers.com/template...s/qbar_pbl.gif http://site.wikianswers.com/template...s/qbar_pbr.gif http://site.wikianswers.com/images/blank.gif http://site.wikianswers.com/images/blank.gif http://site.wikianswers.com/images/blank.gif [/align] 1-8-4-3-6-5-7-2....no. 1 is at front right hand side of engine [when looking at it from in front of car with bonnet open].....behind no. 1 on that side are all the odd numbered cylinders [3-5-7] on on the oppsite side starting with 2 are all the evens [4-6-8] |
Are you replacing your plug wires, have you switched a couple, if so here is a diagram for the coil pack.
DISCO II COIL LAYOUT TOP PASS. SIDE DRIVER SIDE 8 5 6 1 2 3 4 7 BOTTOM |
