ABS AMIGO Codes Read, Please help!
Active Faults:
022:ECU Gnd or Reference Gnd bad 064:Front Right sensor electric fail 065:Rear Left sensor electric fail 066:Front Left sensor electric fail 067:Rear Right sensor electric fail Logged Faults: None <-END Faults Also, the downhill decent control light went out but the ABS and TC Lights remain on. Thanks for your help in advance! |
Looks like a bad ground somewhere from the ecu, doubt all your sensors are bad. See the Rave manual for all the ground points to check.
Thanks for the lead!
I am researching RAVE as we speak! |
Alright well, i have looked at the RAVE manual under the electrical diagrams and have found some of the wiring positions for the ABS sensors under the connections section. I have a multimeter and am willing to go hunting, but i am a little new to the electrical side of things... anyone have any more clues?
I remember reading an article about abs faults caused by bad grounds with some common locations. I'm pretty sure one was on the firewall, drivers side somewhere. I have the article saved on my home computer, I'll take a look tomorrow.
Here's the link, looks like a good place to start
http://www.roverparts.com/TechTips/S..._Test_Proc.cfm |
