ABS Amigo Results
Hello all I got my ABS amigo. Ran the diagnostic. Here are my results.
Maybe somone with more knowledge can tell me how I go about fixing these fualts. Under logged fualts. Electric faults "shuttle valve failure". Does that mean I need to do the ABS modulator fix? Any help would be apprciated. The Amigos only come on about one day every 2/3 weeks. 1.--Current Faults----> Active Faults: None Logged Faults: 114:Shuttle Valve Electric Failure <-END Faults ------------------------------------------------------------ * * ------------------------------------------------------------ ..--Previous Faults---> Active Faults: 022:ECU Gnd or Reference Gnd bad Logged Faults: None <-END Faults ------------------------------------------------------------ * * ------------------------------------------------------------ ..--Previous Faults---> Active Faults: Comms Error Logged Faults: Comms Error <-END Faults ------------------------------------------------------------ * * ------------------------------------------------------------ |
It is time for you to read Josh's ABS Sticky at the top of this section, then get back to us with what you plan on doing.
