ABS Code 115
I have been getting random three amigos recently on my 2001. The lights always reset when i turned the ignition off but they always would come back. Sometimes a couple of days until the 3 amigos are back other times several weeks. I finally got an autocom and read the codes. I am getting a 115 unknown fault. I reset this and it keeps coming back. I am not sure how to attack fixing this code. does anyone have any idea what this code is? I have searched and havent turned anything up.
Thanks |
I don't think there is a 115 ABS code. You might try finding someone with an Autel or an ABS Amigo and see if they can scan for a code.
I have the same code but my AutoCom won't clear it. Did anyone figure out what it is?
Did you solve this? I am getting the same code
Any luck with this, the same code just popped up on my '04 with 94k on it. Sorry to bring back a 3 yr old thread.
Try option B on Shuttle valve rewire. Get codes cleared, and see if they go away. Mine did including p1590, wheel speed sensors, and shuttle valve failure. Everything is good thru the pre-start test, and haven’t thrown an ABS code since. |
115 code
There is a reference to a P115A code on the net. It pertains to “Low Fuel Level - Forced Limited Power” and references the fuel level sender. However, it’s not ABS related.
https://www.google.com/amp/s/www.aut...and-rover.html |
| All times are GMT -5. The time now is 11:44 PM. |
