abs...codes...and rumbling noise + ticking noise
i got a p1509 and p0455, the p1509 comes with a rumbling noise coming from the abs pump and the p0455 comes with a loud ticking noise exhaust leak?
help once a again! Joe |
Go are missing on both, the 455 is a gross evap leak, sometimes the gas cap but usually something else.
The 1509 is you idle solenoid clicking, may be failing, may need cleaning. Shout if you have any questions. |
how do you clean it, with what? i guess i wont worry too much about the 455.. what do you think? thanks
remove it and clean it with carb cleaner.
