ABS Extension Question
Hi guys,
Quick question about the SlickRock Fab ABS Extensions. Do they just plug in between the existing ABS wires at the hub and frame, or can I remove the connector from the hub/caliper end and totally replace the wire going from the frame to the hub? I thought the hub sensor was permanently installed, but the SlickRock wires are REALLY long and I'm not sure what to do with the excess. Thanks for the help. Here's the website: SlickRock Fabrication -- EE -- Expedition Exchange Incorporated |
Just plug in. But they re bout 10" longer than I needed.Mine are just looped and zip tied.
Originally Posted by ebg18t
(Post 335951)
Thanks for the response. So I don't remove the wire from the hub? I'm going to have a lot extra lol |
Originally Posted by willrok13
(Post 335962)
Don't waste your money buying a set of extensions when all that is necessary for a 2" to 3" lift is unplug them and reroute them for better articulation.
I have a near 3" lift and never replaced mine although it is good to replace the rubber brake hoses with stainless steel extensions. |
Originally Posted by Disco Mike
(Post 335987)
I would probably do that before buying a long set of extensions that will then need to be looped to keep them out of the way.
(Post 335987)
