abs light on
abs light on
Hi I just changed the pads & rotors on my 99 Discovery 1 and now the abs light is on from time to time. The brakes also pulsate from time to time when I brake. I used regular generic pads & rotors. I've read that cleaning the sensor can help clear this? If so, where is the abs sensor? Any advice on how to troubleshoot this? Thanks.
on
RE: abs light on
There should be a sensor on each wheel, specifically where I'm not sure as I have not dived into this. My sensor comes on from time to time as well. A while back I took it to Land Rover and they said my left front sensor was just falling apart and that "they just do that". They gave me a ridiculous quote as it's something I can do myself, just was never too concerned over it. Your getting occasional brake pedal vibrations because one of your sensors is not recognizing the wheel and sending a signal to deploy abs. I recommend that you unfortunately take your tires off one by one and make sure your sensors are seated properly. They trip easily if they are not in that sweet spot.
