ABS Pump Failure
I recently replaced the shuttle valve on my 2004 Discovery because some one had do the wiring trick on the ABS and I kept sliding around on locked brakes anytime I pressed them. After putting a new valve the brakes felt way better and never locked up. But the three amigos popped up so I went to have them checked and I got the Pump Failure 1 (monitor line) & 3 (pump sticking) as well as the shuttle valve switch failure. The shop told me I needed a new pump and I grabbed my keys and headed out after the quote. Ive been roaming the forum sites for answers but theres not any clear ones. Anyone have some straight forward suggestions or solutions? Cheers!
P.S. could I have not plugged the shuttle valve plug in all the way to bring up all these codes? just a thought |
ABS pump failure is extremely rare on these trucks. I've actually never heard of one single case. These trucks electronics are very sensitive. Id try just reseting the light and driving it awhile a few times before I threw anymore money at it. Sometimes just doing a repair will trigger a warning light on these trucks. Make sure the brake fluid level is right. Just putting the shuttle valve on nice and tight should make a good connection, so I doubt it that.
Shuttle valve wiring fix should NOT have caused anything to lock up. Maybe they did something wrong? What color wire did they tap into?
they cut into the green and yellow wire for the wiring job. since ive gotten the disco back from the shop the lights have turned off for the first time but have popped back up under braking and have gone back away after restarting the truck. could it be a bad connection somewhere? i may try flushing the fluid and putting new fluid in to see if that helps
I used to get the 3 amigos after a hard bump in the road or when the brakes squealed, even after I did the A fix and B fix in the modulator.
So if the modulator is ok then have a good look at your four wheel hubs, clean the dust shields, remove rust lumps between hub and shield if there are any, clean and grease the slide pins with the correct grease, and make sure the brakes pads don't squeal. I bet you won't see the 3 amigos again. It took me a few tries to get it right though, but now I am 3 amigos free... |
I'd come up with some way to read the codes. Anything else is just guessing. Sometimes educated guesses, but guesses none the less. :)
Originally Posted by kfx4001442
(Post 501763)
Lots of reading here about shuttle valves and modulators.
https://www.google.fr/search?q=disco...m=122&ie=UTF-8 |
Worth a chat with these guys, they almost speak the same language ;) and should be able to help. :)
Land Rover page | Falconworks' Quality Auto Repair | Jaguar, Alfa Romeo, MG, Lotus, Triumph, Austin Healey |
Originally Posted by jafir
(Post 501854)
