ABS Sensr Cleaning
ABS Sensr Cleaning
I have seen several times on this forum the recommendation to clean the ABS sensors to help with intermittent 3 amigos.
I recently replaced the breaks and rotor with the recommended ceramic pads and everything is great (breaks work better than ever and no squeaking at all).
I borrowed a Amigo and I had no codes active or stored.
My 3 amigos come on about once a day. If I shut off the truck and restart they will stay on.
If I shut off the truck and let it sit for a while or overnight they are always off when I restart.
My question is that the Land Rover Workshop Manual says that the:
"ABS sensor is supplied fitted to wheel hub and must not be removed."
If this is what the manual says, how do they come out to be cleaned and does this really help?
Thanks,
Thanks,
At the time I had the amigo scanner tool they were off but I thought it would have stored previous codes.
I was hoping that since I had a lot of old brake dust (and I mean a lot!) from the old brakes that cleaning the sensor would help.
But I didn't see any way in the shop manual to remove/clean the sensor.
johnkbl
01-13-2009 08:54 PM
