AC blowing warm on passenger side
Searched for Blend Door, but haven't found anything in the rave that matches it or my problem as of yet. Would it even be possible for the charge to be going bad, but only affecting one side of the system? Even the rear air is blowing cold as can be without a hiccup?
Sorry, I used the wrong (non-LR) terminology. Page 1162 (80-5) shows you where the doors are. You basically want to check that the RH, LH and distribution control cables are working (moving). Those move the blend doors, or whatever LR calls them.
Sounds like the RH cable may be bound up, or the servo that moves it is bad, or the blend door it moves is stuck on something.
The AC can't only go to one side from a charge perspective, as there is only one evaporator coil (the thing that gets cold and the air blows through).
I've put arrows on the things I think are most likely to be a problem for you:
Those pictures are both right hand drive and without air conditioning (yeah, it can't get any further from yours unless it was another vehicle...sorry). But they are close, and will get you looking at the correct things.
many thanks
Ran diagnostics and had fault code 21-22 which is the sunlight sensor, so now i am stumped again.any suggestions? Also, This morning i am out trying to figure this thing out and both sides are blowing ice cold. Could it be that due to it being 110+ all darn day that the truck itself and the componenets get so hot it just takes longer to get the system cooled?
Young
07-22-2009 07:51 PM
kfx4001442
06-23-2009 06:45 PM
