AC drain line location?
I found the two nipples on each side of the transmission. Is there one I missed or is there two of these nipples on one side? I checked both, and I'm still getting AC water in the passenger floor. BTW, this is a 96 Disco I.
Help! |
RE: AC drain line location?
Did you "ream" out the drain tubes? Or did you just drain the water?
I drained the water that was on the passenger side but I didn't stick anything in there. A lot of watercame out, but I was thinking that water was from the last time I washed the truck. We haven"t had rain in over a month.
No other water than from the A/C condensation will get in there, those drain tubes are dedicated to the A/C.
Take pipe cleaner or some other type of stiff bristle and stick in the drain tube to clean any dirt out. |
So do these lines also connect to the drain lines in the sunroof's?
That I do not know.
Spike thanks for your help. I'll get some pipe cleaners tomorrow and see if that resolves the issue.
I did mind about two weeks ago. Word of advice⦠prepare to get wet. lol
I didn't end up having to fool with it again today. It drained properly all day today[sm=closed.gif]
| All times are GMT -5. The time now is 03:09 AM. |
