-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   ACE (https://landroverforums.com/forum/discovery-ii-18/ace-11269/)
brooksa Jan 14, 2008 11:28 AM
ACE
How do you tell if a DII has ACE? 2004 SE7
spoon Jan 14, 2008 11:31 AM
RE: ACE
Look underneath the truck real quick. If you see hydraulic rams in the place of anti-roll bars, you've got ACE.
spoon Jan 14, 2008 11:41 AM
RE: ACE
Actually, I guess the AR bars are there in fact, but here's a pic that might help you out. Also, look in one of the fuse panels. There should be a fuse for the ACE sensors, right?
http://img232.imageshack.us/img232/5817/acejd6.jpg
R_Lefebvre Jan 14, 2008 12:17 PM
RE: ACE
Is ACE just "something else to go wrong"? Is it more reliable than the brake system? Is it a hinderance off-road?
spoon Jan 14, 2008 01:25 PM
RE: ACE
A hinderance off-road it would seem like to me... but it all depends on what kind of offroading you do. If you go rock crawling, you would probably benefit with the removal of the anti-roll bars and ACE system. Also, the ACE has nothing to do with the braking system. It's just a system that, by alternately stiffening the appropriate sway bars, greatly reduces body roll during hard cornering.
humroot Jan 14, 2008 04:24 PM
RE: ACE
Look at the power steering tank. If it's divided in half and the second cap has a pic of a car with 2 arrows, you have ACE. ACE (Active Corner Enhancement) will let you take on and off ramps at high speeds; it keeps the truck level during turns.
