Advice on how to bypass alarm without fob key
Hi guys
Land Rover Discovery 2003. I hope you can help me. I took my car in for an oil change. When they were done, they parked it outside and handed me the key. I put it in the lock to open, the lock just rotated! The alarm was flashing. The guy noticed one of the doors wasn't closed properly. Locksmith got me into the car. The car won't start. All the lights go on on the dash, the windows are working, it just won't start. I am assuming this is because of alarm, the car thought it was being stolen and shut down. I don't have a FOB key or remote.This happened two nights ago. Here's what I've done so far: I left the battery disconnected, the red side, overnight. Nothing changed, still won't start. Made tons of calls, Land rover gave me the four digit code for a Fob and told me to call lock shop, I called all over town, nobody I talked to makes Fobs for Land Rover. Someone told me I can bypass the alarm by taking out the door panel, there will be something at the back of the lock I can remove, that will enable me to start the car.I took out the panel and found that the lock is broken inside, there's a bronze rod written r33077 that's broken. I think that's why the key is just spinning. Land Rover said to tow the car in today. I am moving to another state this weekend. I am all packed and serving the last few days of my notice, I need the car asap. If you know of anyway I can drive this car, I would be so grateful. Please help me Thank you |
where are you located? I have the rod, I bought it thinking mine was broken but it wasn't.
I never used it and have it somewhere in my garage. |
Also, if it's just the rod that's broken, you can turn the actuator with a knife to unlock it. That should disengage the alarm.
I'm in Vegas, Fuddy. You?
Originally Posted by Fuddy
(Post 501752)
I tried taking out the lock yesterday, after removing the door panel, but one of those screw like things that require a star shaped screw driver head to remove, by the latch side of the door, is messed up. Looks like someone tried to remove it with the wrong tool before. How else can I take out the actuator? |
Babsido, here is a thread I started a few years ago on another Rover forum about the lock rod failing and how to repair it with a 20d nail.
Driver's door lock cylinder spins - '99 DII - DiscoWeb Message Boards As for the star-shaped screw I presume that it's a Torx head. A Torx screwdriver or nutdriver bit may be able to get it out even if it is buggered up somewhat. |
That 4 digit code isn't for a remote. It's either the code for the metal part of the key or it's the EKA code, neither of which will help you if the key doesn't work properly in the door lock. The first stop would be to get that corrected, and then once the system is disarmed, I'd try to get a remote synced up with your BCU so that you have two (or three) ways of disarming the system.
Originally Posted by mln01
(Post 501796)
Originally Posted by jafir
(Post 501797)
(Post 501796)
