Aftermarket Radio Help...
2000 Disco 2 with the Harmon/Kardon sound system.... Ive got the wiring diagram but nothing makes sence. Ive found the power wires for the radio but that is as far as I can figure it out. Im needing help decifering the amp input (Yes I have RCA Adapters) and the amp trigger. Any advice would be appreciated before I gut the whole thing.... The factory sound system rocks but I have no tapes and no CD Player in there. I really dont care about the steering wheel controls. Thanks
RE: Aftermarket Radio Help...
Check under your passenger seat. There is a little door. Open that and make sure you don't have a cd changer. Anyway, the ampinput appears to be the gray/green stripe wire of connector C0922 pin 9. The amp receives power when key is on. The RCA cables will only do you good with an aftermarket amplifier.
There is no CD changer under the seat. I wonder if someone took it out or something because it looks like all the provisions are right there. Im not that interested in a changer anyways, I just want to hook up my kenwood up so I can play my MP3's and my Satallite radio. I really dont want to gut the system because it is a really well ballanced system.
slackwaresupport
10-11-2006 11:32 AM
