-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Air suspension compressor (https://landroverforums.com/forum/discovery-ii-18/air-suspension-compressor-77797/)
LR03NJ Feb 16, 2016 06:21 PM
I got a 04 disco few months ago with a converted air suspension to spring. I guess I can still hear the compressor running once in a while and I have some few questions:
-How can I disable the motor or components related to the air suspension?
-I want to replace with ARB shocks and springs. Are the mounts compatible with after market springs and shocks?
-Can the compressor be modified as an air compressor to pump the tires?
THANKS
Joemamma1954 Feb 16, 2016 08:15 PM
Are you positive it is the air compressor running? The SAI has a compressor(of sorts) that blows air into the exhaust and it comes on when called upon by the ECU, normally at cold startup. If it is the air compressor, I believe there is a relay that turns it on and can be pulled. Someone a little more versed can chime in here.
drowssap Feb 17, 2016 05:48 AM
if you think it is the compressor for your suspension just pull the relay under the hood.
yes if it already running coil not a problem, replacing with coils.
No that compressor will not work for tires, it would burn up before you got one inflated
