Originally Posted by nychaze
(Post 345736)
I fell for the toddco trick....shame on me
Its not a "kit" all the damn thing is the front output housing off any respectible disco that had a locking CDL. Call Paul Grant (dMike signature has contact info) or any other LR used parts guy and they can get you what you need a hell of a lot cheaper than toddco...and you dont need to buy a whole case just the front output hosing (weights 10-20 lbs) cheap shipping...even if you can get an entire case at $200 shipping will reem you good.... 8 of the 16 cross member bolts snap when i did mine...start soaking them now and run an impact on them when you do take it off....the heads will snap off before anything else and make sure you use a 6 sided impact socket. Also, I didn't realize it wasn't a complete kit, that's pretty BS false advertising. I think I'll continue to look for a complete 04 DII t-case with linkages, then I'll have mine as a back up if it fails. |
Where to get a lever?
I'm ready to install my own version of the push/pull cable. I'm having trouble coming up with a lever to bolt to the cdl nipple. Suggestions?
Has anyone purchased rom this seller in Poland? Looks like a good deal for a new assembly for $349:
CDL Land Rover Discovery 2 D2 Central Difflock Diff Lock Shifter | eBay |
yes I bought it a couple of years ago when he first started selling them, I think I paid $249.00 works great. I did have to enlarge one hole but it works great and it doent have the factory solenoid on it.
| All times are GMT -5. The time now is 02:49 AM. |
