Alternator brand
Old 11-20-2022, 12:33 PM
Richard Gallant's Avatar
Received 1,175 Likes on 812 Posts
Default Alternator brand
My alternator died hard, any feedback on best brands - managed to get drive about 20 miles almost got home on the dead on
Looking at a 130 amp by either AC Delco or PURE ENERGY both remans
Old 11-20-2022, 12:40 PM
Best4x4's Avatar
Received 2,297 Likes on 1,688 Posts
OEM is either Bosch or Valeo (depending on year). If you get a refurb (no matter the brand) it'll be a repaired Bosch or Valeo core more than likely.
Richard Gallant (11-20-2022)
Old 11-20-2022, 02:06 PM
acg's Avatar
acg
acg is offline
Richard, I am glad you made it home without the truck stalling. I could not take off right behind you as we were dealing with Deb's truck. Her oil cooler line came lose as was leaking even more oil. I tried to raise you a few times on the ham to get a status check.... then realized you must have turned your electrical stuff off.
You can also use the P38 Alternators @ 150 amp instead of 130 amp.
Old 11-20-2022, 02:39 PM
@acg @Best4x4 Good news my spare that was in a bucket works great, 14.6 volts on startup cold. still need a new one as this was just a used spare.
Andrew got to Husky just before Mission when the voltage got too low, parked and called BCAA. Drove onto the tow truck and drove drove off so that was nice.
Old 11-20-2022, 04:32 PM
Best4x4's Avatar
Cool glad the spare works! I would slap in a P38 model as the extra amps certainly won't hurt.
Old 11-20-2022, 11:57 PM
Brandon318's Avatar
Any downsides to using a P38 alt? Just added (but probably not much?) power drag on the engine I'm guessing?
Old 11-21-2022, 12:05 AM
@Brandon318 no extra drag of any note. The upped amperage helps if you run a lot of stuff internally for example my radio (on high power transmit) and all my USB stuff combined pulls about 25 amps max. Even upping to a 130 disco alt can help, but price wise there is very little difference so it can not hurt.
Old 11-21-2022, 08:57 AM
yup thats what i did p38 all the way
Old 11-21-2022, 10:37 AM
jacobmstein's Avatar
Scratch & dent part for a good deal: https://www.roversnorth.com/parts/pl..._cracked_cover
I bought a 130 amp alternator from AB recently, turned out to be a Terrafirma part.
Old 11-21-2022, 03:14 PM
Motorhead1's Avatar
If your alt just quit charging, you can replace the voltage reg with a kit for around 25 bucks. FYI
Quick Reply: Alternator brand
