-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Alternator Going Bad? (https://landroverforums.com/forum/discovery-ii-18/alternator-going-bad-24264/)
Spike555 Sep 19, 2009 06:00 PM
Originally Posted by Carl082974 (Post 138934)
The used alternator arrived today, it is in good condition.
But I ordered a 2001 alternator and they sent me a 2000 one.
I think it should be ok because the same part# was used for both 2000 & '01.
Can someone confirm this???
You are fine, all DII,s use the same alternator.
Not sure if the DI and DII use the same one or not though, but yes, you are perfectly fine.
JumPeR04 Dec 13, 2009 01:39 AM
My alternator went out a wk ago so I had to go get a used one and got it testing before I put it on and I made sure that All cables and wires were tight but it still want to act like it doesn't want hold a charge lights dims and starts wanting to died on me so I don't know if the belt is bad or what
Mrmerlin Dec 13, 2009 06:35 AM
get a multi meter and check for charge at the battery if its lower than 13.4 then the battery will not get a full charge . A good charge system will run from 13.5 to 14.5 at about 1500rpm
JumPeR04 Dec 13, 2009 08:17 AM
I brought a new battery like two wks ago but I will try that
JumPeR04 Dec 13, 2009 12:56 PM
Ok had the battery test and it is good but belt is still want to whine and so do you hits thinks I should chang out the belt
JumPeR04 Dec 13, 2009 07:00 PM
I just change the belt and everything is good but the rpm are beyond 1 idle and half way between 1 and 2 when I hit 50 mph
