Amigo help
Amigo help
04 Disco. Three amigos and brake light are on. Mechanic says need to replace brake sensor and abs modulator based on codes. Two questions: 1. I need new brakes - could that be what is causing the lights? 2. Any harm in not doing the work and just rockin on? Disco drives and brakes fine.
on
I would not trust that mechanic at all, unless he can show you the scanner with the ABS fault codes, cause very few have a scanner capiable of reading the codes and to need to replace the module and speed sensors is too much.
Get a second option from a shop that will read the codes, right there in front of you. If the module is bad, they can be rebuilt for $120 in parts and 2 hours labor.
bullcrew
12-29-2009 09:32 AM
