another blinking odometer
So one of my cluster lights went out today and i went to autozone bought 3 new ones put them in put everything back together and started my truck then walla my odometer started flashing WTF? I am just curious how much does this cost to be reconnected to secondary odometer. I have owned this truck since brand new this is my first issue. Oh has 102,000 original everything, except front driveshaft, proper maintenance, proper fluid changes, never had a code or light period. This one is a good one!
Not practical, not a mechanical link. Ultra Gauge or scanner can show speed, not sure if it can total miles. Dealer can reset the flashing odometer.
You need to go to the dealer or a Rover shop that has the proper computer that will reset the speedo to communicate with the ECU and you should be fine.
Ok great thanks, did it just happen because i disrupted the power supply?
u caused system to think you swapped clusters to sell with lower miles. all that stuff stays synced and dislikes change
Thank you for your expertise. I am a lifetime rover owner and never want to sell this one!!!
