Another electric fan conversion, for $70.
#32
i found it online looking at ads for radiators for our truck, then looked at fan shrouds of V8's ads to get one that would cover it.
The '05 GTO Shroud covers the entire radiator, it takes trimming to get it on.
also, for anyone who does go to an electric fan I would recommend having it come on with the A/C. I cannot be 100%, but I think that not having my electric fan come with my A/C may have caused some A/C electrical issues.
#33
I wouldn't tie mine in to the AC. You want your primary fan to run independently of the AC. Unless you've got some wiring crossing over somewhere there's no way the fan has caused AC electrical issues. If I did it again I'd just leave it wired to turn on with the accessories switch and not even worry about a controller. Not worth the extra cost considering you don't actually gain anything from it.
#34
Did you ever wire the electric fan to a thermostat?
I can wire it to come on with the engine, or add a switch.
But, is there a way to wire it to come on with the electric fan in front of the radiator?
I *assume* trying to run a second electric fan off the same circuit as the front electric fan would be too much, and blow the fuse?
Is there any way to tap into the front fan's thermostat?
Thanks
Thanks
#35
Thanks
Thanks
Sixpack577 (07-27-2017)
#36
Or a switch on location in one of the fuse boxes?
It actually wouldn't matter would it?
Is there even an empty location in a fuse box to do so?
Sorry for such simple questions, but the wiring diagrams are something I've yet to have time to look at in detail.
#37
Thanks
Thanks
The issue with that is that the fan in front is only an auxiliary fan that doesnt come on until 212*. You don't want to get that warm.
I ended up just getting A $30-35 adjustable controller. I wired it straight to the battery. There is no drain when the fan is off and it doesnt run for ling after the engine is shut off. Been that way for over a couple years now I think and hasn't caused me an issue once.
I did wire up a switch under the hood for water crossings but have yet to use it other than for testing.
#38
And power that directly to the battery?
#40
And running it on a constant hot wire is just asking for a dead battery. Travel a short distance in hot weather, with the AC, lights, radio, and electric fans running, only then to shut the vehicle off to let the fan run on and off (possibly for another 10 minutes) will quickly leave you sweaty and irritated. Tapping in to a keyed power source takes no extra effort.
