I have a 1996 Land Rover Discovery. Just got new front rotors and pads last week. The other day my Anti Lock light lit up. Anyone out there know why or have any suggestions? My brakes work fine. Thanks.
Go back to where you did your brake job and make sure the wheel sensors aren't loose or broken. If they get out of place just slightly they will trip the ABS light. My guess is after you did your brake job u may have just loosened a sensor or something.
Good place to start, have them pull the codes, write them down and clear them, if it comes back on again and you feel there is a problem get us the fault code numbers.
Mike
