Antifreeze leaking around the throttle body?
Old Jul 11, 2010 | 10:40 AM
pvenuti's Avatar
Default Antifreeze leaking around the throttle body?
On the driver’s side I can see it dripping from the throttle body onto the engine. I see there are two small hoses and replaced one that looked suspect but it’s still dripping away. There seems to be a small cast plate that both hoses connect to. Could that plate have a hole or crack in it? Anyone know what that part is called and if there available.
Old Jul 11, 2010 | 10:48 AM
Rovin4life's Avatar
http://www.roverparts.com/Parts/MGM000010KG.cfm
Throttle plate kit. buy two small hose clamps as well.
Old Jul 11, 2010 | 10:53 AM
pvenuti's Avatar
Thanks for the quick response. I take it this is a common problem for people to have?
Old Jul 11, 2010 | 11:01 AM
Rovin4life's Avatar
welcome to rover, if it has a fluid in it it leaks. And even if it doesn't have fluid it will break down cause fluid will get on it.
Old Jul 11, 2010 | 11:03 AM
pvenuti's Avatar
Ok got it.
Old Jul 11, 2010 | 11:49 AM
vandev's Avatar
Default replace it or bypass it...
You can replace it or bypass it if you live wher its hot most of the time....
easy fix...
Chris
Old Jul 11, 2010 | 01:29 PM
There is a write up on how to fix this in the write up section.
Old Jul 11, 2010 | 02:12 PM
pvenuti's Avatar
Thanks everyone for the responses
SenatorPerry
Jul 15, 2013 10:28 AM
jr99rover
Oct 25, 2010 07:34 AM
boom_r6
May 1, 2010 07:41 AM
firstcoast
Mar 8, 2009 01:01 PM
Kennydhl
Aug 3, 2005 05:28 AM
