Any pro "broken bolt extractors" out there?
When I was doing my front cover gasket I had to remove the front most crossmember. One of the bolts was rusted in there pretty good and I broke it off with the bolt flush with the frame. I would like to get it out even though it is probably OK with the other 7 bolts holding in on there. So I have never had much luck drilling out bolts (always end up drilling too much and killing the threads). I bought a set of the easy out bits for my drill and I have a torch. Anyone a pro at getting out broken bolts and have any pointers?
and what ever you do DONT overload it!!!.........If the "easy out" snaps, as they EASILY do, they are ROCK hard, and you won't be able to drill it out, it would need grinding out, and that takes a LOT of time.
When using these easy outs, you have make sure you have or do drill centrally, because if the hole is off centre and you drill through to the edge of the hole, the easy out grips what ever the bolt is going into and that usually dont move, this can contribute easily to the easy out snapping as you try to twist out the broken bolt.
My advice would be to soak the bolt (if you can) in some penetrating oil first, give as long as is feasable soaking, when drilling it that will "heat" it up quite a bit as well, if its already drilled, then heat it with a blow torch just before you go to remove it.
If you can chase down a Snap-On dealer ask for Bluepoint kit # 1020 "screw extractor set".
it come with the drills, guides, and splined inserts that are a little more durable than the regular easy out, and allows you to put a real wrench on the problem. This will handle sizes from 1/4" to 1/2 " and their metric counterparts. and all pieces are available separately for replacement. This has saved my A@& countless times at home and at the shop.
The easy way to remove broken bolts: MIG WELDER If the bolt broke flush,weld on the end of the bolt,small welds,build the broken bolt out to beyond flush. Place a nut over the "pile" of short welds,now weld the nut to the pile of welds. Quickly use a socket and breaker bar to wiggle the nut back and forth until it gives up! Most times no additional heat is needed. Works great removing broken bolts from aluminun heads etc.
smokin
09-06-2013 01:19 AM
me 2
03-28-2013 11:02 AM
ValveCoverGasket
05-23-2012 10:33 AM
impretzle
04-13-2011 12:40 PM
