Any trick to get out of limp mode?
I got the 'ol M and S flashing thing randomly a couple weeks ago. Turned it off and back on and it went away. Now it's back with a vengeance, coming on consistently when I turn it on. I'm pretty sure it's something electrical, like a loose cable or a bad alternator, but I'm looking for a temporary way to get it to shift normally. I tried tricking it by shifting into 3rd then D but no dice. Are there any workarounds on this? I thought I read about one recently but can't seem to find it.
In my case no S&M until backing and then shifting into forward. If a circular drive or when creatively parking would never go into limp.
That's what I did for a at least a month prior to switch R&R. Fortunately was already using a ScanGaugeII, was able to back out of drive and easily clear fault while underway. Sometimes it wasn't a set just pending or not even pending, S&M flashing and obviously in limp.
Bottom line, there are ways to reset/clear fault other than a stop/restart and you'll likely be good to go until S&M/limp again.
Rickey_240
04-02-2010 05:33 PM
xb70valkarye
02-02-2010 10:13 PM
