-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Anyone replaced a torque converter? (https://landroverforums.com/forum/discovery-ii-18/anyone-replaced-torque-converter-118100/)
miron Jul 22, 2023 02:21 PM
If anyone has replaced the torque converter, I'd really appreciate any pointers on how and what should I be looking out for.
thanks!
sdtimb Jul 22, 2023 11:48 PM
I haven't, but the instructions should be in the RAVE (D2 workshop manual). Do you have a copy?
miron Jul 23, 2023 12:02 AM
I do have a copy, but you know there are always some special tricks etc.
Alex_M Jul 23, 2023 06:55 AM
If you're replacing the torque converter, you really should replace/rebuild the trans and flush out the tranny cooler lines at the same time. The debris from your old converter will have gone through the entire system.
miron Jul 23, 2023 12:27 PM
That was the plan, but the rebuild kit costs as much as a whole transmission from a wrecker. I'll see what shows up on the filter, but it's hard to justify paying $400 for a few gaskets.
Extinct Jul 23, 2023 02:37 PM
Alex_M is right, just swap the entire transmission. They almost never go out,better use of your time and money to just swap it.
miron Jul 23, 2023 03:10 PM
Yes, sorry the "rebuild" somehow got stuck in my head. Replace is definitely a viable option.
Richard Gallant Jul 23, 2023 05:46 PM
@miron If you doubts have it done by a shop, Automatic transmission and brakes if you are not sure get it done professionally.
miron Jul 23, 2023 05:50 PM
I don't have issues with the mechanical part. It's mostly the financial side of thing.
Also on another note, why does a rebuild kit for the hp22 doe a bmw cost half as much ase the one for LR? They seem to be pretty much identical...
ahab Jul 23, 2023 08:03 PM
If it’s a 4HP24EH then it’s the same trans. BMW also used the 4HP22, which I think is a D1 trans. Either way, the kits should be the same for their respective transmissions.
