Anything i should do before starting a newly installed 4.6?
Old 03-17-2010, 07:49 PM
Willie00d2's Avatar
make sure the ground strap is bolted onto the drivers side head in the back of the engine. I just did a head gasket job and forgot to put that on before putting the heads on. There is less then an inch gap there. I had to ground the engine to the intake manifold instead.
Willie
Old 03-18-2010, 11:49 AM
DiscoWest's Avatar
Originally Posted by Spike555
But the ecu will re-learn the new engine, but it will take 500 miles or so.
So it will learn the characteristics of the new engine as a 4.0 or learn that it is a 4.6 and perform as such? If so, I can wait the 500 miles rather than taking it somewhere to reprogram, as I don't have a Rover specialist anywhere close.
Old 03-18-2010, 11:51 AM
DiscoWest's Avatar
Willie
Good tip thanks
Old 03-19-2010, 09:56 AM
okdiscoguy's Avatar
It will re-learn as a 4.0.
Old 03-19-2010, 07:54 PM
DiscoWest's Avatar
OK thanks, a running motor is the first priority now anyway
ToddD
02-21-2014 04:37 PM
dbackbmx3
07-08-2009 08:55 PM
kingsly
06-21-2009 11:13 PM
andrewmcoffin
05-18-2008 08:43 AM
jmt
03-11-2008 11:43 AM
Quick Reply: Anything i should do before starting a newly installed 4.6?
